Layers menu not showing in  NLiu's TOC widget
6046
11
06-13-2014 12:56 PM
banumsbanums
Hi, I am trying to add the layers at http://gis.fema.gov/REST/services/FEMA/Surge/MapServer to  NLiu's TOC, but the layers are not visible in the TOC widget menu. Any suggestions please
JeffPace
That site has a custom installation, no "arcgis" application and SOAP end point seems deployed separately. If upgrading to 10.01+ is not option, you need play with http://utility.arcgis.com/sharing/tools/legend with that site until you can figure out how to get a legend JSON file. It would helpful if you have access to admin.
Thats why I hardcoded json files.  I couldnt trust some sites to deliver a properly formated json
Thu_GiangDang
I'm having a similar problem with the JSON request. In the example the this request (//hostname/arcgis/rest/info?f=json) goes through without problem:
[ATTACH=CONFIG]34637[/ATTACH]
However when I tried with my local map services (published with 10.2 server, have legend info), the request gets canceled everytime:
[ATTACH=CONFIG]34638[/ATTACH]
Any suggestion how to fix this would be most welcome.
