Layer List Widget
3415
10-23-2015 12:49 PM
jaykapalczynski
Honored Contributor
Layer List Widget....I am trying to use the example below but reference a Map Service instead of a web map....how would I do that?
    //Create a map based on an ArcGIS Online web map id
    arcgisUtils
.createMap("df8bcc10430f48878b01c96e907a1fc3", "map").then(function(response){
var myWidget = new LayerList({
           map
: response.map,
           layers
: arcgisUtils.getLayerList(response)
},"layerList");
        myWidget
.startup();
LayerList widget | ArcGIS API for JavaScript
KenBuja
MVP Esteemed Contributor
Here's an example that uses a map service and shows how to wire up its components
JS Bin - Collaborative JavaScript Debugging
KenBuja
jaykapalczynski
Honored Contributor
Thanks
