Lasso Selection and Rectangle Selection not tracking mouse
352
03-11-2026 10:48 AM
AndrewMurdoch1
Good Day
I just upgrade to ArcGIS Core 4.34.8 and now my mouse isn't tracking with the Lasso or Rectangular Selection Tool.  When I select them and start to draw, the area is pinned into the top left of the map.  I saw this behaviour first with the SketchWidget, so figured it was a deprecation issue, but I see the issue with the web component.
(view in My Videos)
Do you have any idea how to fix this?
Thanks
AndrewMurdoch1
Fixed it,  I had
@import "https://js.arcgis.com/4.20/@arcgis/core/assets/esri/themes/light/main.css";
In my map CSS, changed it to:
@import "https://js.arcgis.com/4.30/@arcgis/core/assets/esri/themes/light/main.css";
And it's fine now, so if you run into this, please make that change if you want to keep your sanity.
