Label text in [fType] or [fName] but not both fields
825
07-10-2010 09:19 PM
ShaneMcGovern
I am not a programmer and find Esri VB script challenging. What i want is to label a feature if it has a name from the [fName] Field, and if that field is empty then use the [fType] field.
Also sometimes the [fName] field has a ""."' which i want to ignore as well.
Could someone help me out with code or explain simply how i could work it out.
Shane
derekswingley1
This is the ArcGIS API for JavaScript forum...you might want to try the Desktop forum:  http://forums.arcgis.com/forums/5-ArcGIS-Desktop-General
