KML to SHP conversion error Error using ArcMap's Quick import tool
1056
08-01-2011 10:10 PM
MehwishAli
I had a line shapefile that i exported that to kml,verified that via google earth,now I am using ARCGIS 9.3 "Quick import tool" to convert polylines in kml format to shapefile...It reads some features while leaves other features and in the end says that tool execution failed.The error says:
"The xml module halted on error,see logfile for details
Error encountered while reading a new node
Error reading feature from dataset"
Can anyone explain what the error is about and how can be corrected?
derekswingley1
I think you would be better off posting in the Desktop forum:  http://forums.arcgis.com/forums/5-ArcGIS-Desktop-General
