KML Placemarks
5514
07-24-2015 07:04 AM
CharlesGant
Hello,
This might have been discussed before but I couldn't find anything doing a search.  I'm trying to pull in the following kml and display it using the esri js api.
http://www.wpc.ncep.noaa.gov/kml/qpf/QPF6hr_f00-f06_latest.kml
However, the placemarks are not displayed correctly.  Is there a way to remove them altogether, or display them correctly?  I tried using the getLayers() method but it just returns an empty array.
Thanks!
ChrisSmith7
Honored Contributor
Charles,
Are you looking to remove the pushpins?
CharlesGant
Yes sir!  All I want are the contours and the shaded graphics.
ChrisSmith7
Honored Contributor
Charles,
hide() does not work as anticipated, for some reason. Maybe it's a bug, maybe I'm not understanding it correctly. Using this sample - ArcGIS API for JavaScript Sandbox - I modified the kml to use the one you posted and here's what I found...
 var layers;
    kml.on("load", function() {
      domStyle.set("loading", "display", "none");
      layers = kml.getLayers();
      dojo.forEach(layers, function(layer){
        layer.hide();
        console.log(layer.visible);
In the console, both layers have visible as false, but they still show. As a workaround, try something like this (using opacity):
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title></title>
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style>
  html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
  #map { height: 100%; margin: 0; padding: 0; }
  #meta {
    position: absolute;
    left: 20px;
    bottom: 20px;
    width: 300px;
    height: 100px;
    z-index: 40;
    background: #fff;
    color: #777;
    padding: 5px;
    border: 2px solid #666;
    -webkit-border-radius: 5px;
    -moz-border-radius: 5px;
    border-radius: 5px;
    font-family: arial;
    font-size: 0.9em;
  #meta h3 {
    color: #666;
    font-size: 1.1em;
    padding: 0px;
    margin: 0px;
    display: inline-block;
  #loading {
    float: right;
</style>
<script src="http://js.arcgis.com/3.14/"></script>
<script>
  var map;
  require([
    "esri/map", "esri/layers/KMLLayer",
    "dojo/parser", "dojo/dom-style",
    "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
  ], function(
    Map, KMLLayer,
    parser, domStyle
    map = new Map("map", {
      basemap: "topo",
      center: [-108.663, 42.68],
      zoom: 6
    parser.parse();
    var kmlUrl = "http://www.wpc.ncep.noaa.gov/kml/qpf/QPF6hr_f00-f06_latest.kml";
    var kml = new KMLLayer(kmlUrl);
    map.addLayer(kml);
    var layers;
      layers[1].opacity = 0.0
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline',gutters:false"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="map"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'center'">
    <div id="meta">
      <span id="loading"><img src="images/loading_black.gif" /></span>
      <h3>Display KML Using a <a href="https://developers.arcgis.com/javascript/jsapi/kmllayer-amd.html">KMLLayer</a></h3>
      <br />
      The map displays a simple KML file that was created using Google Earth and
      is hosted on an Esri server. Symbology and attributes are honored.
    <div>
  </div>
</div>
</body>
</html>
ChrisSmith7
Honored Contributor
Ok, so it looks like hide will work, but you can't key off of the KML load event... it must be too early to call the hide method. It works if I use "update-end":
    kml.on("update-end", function() {
      layers[1].hide();
      console.log("layer hidden");
It doesn't seem to fire this more than twice. Panning and zooming doesn't cause the "update-end" to fire on a KML.
CharlesGant
Chris,
I plugged that code snippet in and it didn't work.  I printed to console the layers array and it printed the array twice with only one entry.  The code you provided should hide the first layer, correct?  That said, I'm only getting an one entry array, not two.  Its like its creating the array as it loops through the layers, not creating the array once with two layers in it.  Any ideas?
I noticed that you were using parser in the top of your code.  I'm using ready(function(){.....}, does that make a difference?
Charles
