JSAPI 4 requesting wrong url when loading WMS from third party geoserver
3105
05-18-2021 06:09 AM
LukasWürsch
Dear all,
I tried to load this third party WMS (https://data.opendevelopmentmekong.net/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/wms) with the following code: (find the full code at bottom of post)
let wmsLayer = new WMSLayer({
  url: "https://data.opendevelopmentmekong.net/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/wms"
map.add(wmsLayer);
The layer does not load and requests are answered with 404. In the networks tab I see that the WMS' url is changed, pointing now to https://developers.arcgis.com/ instead of the url where the geoserver is located (The code was ran from the sandbox. It seems it always takes the url of the current site).
Would I manually replace https://developers.arcgis.com from this request with the proper url where the geoserver is located (https://data.opendevelopmentmekong.net) I would get the right response.
The problem occurs only for some WMS, it works for example for https://ahocevar.com/geoserver/wms
Is it possible to load the former service with ESRI API 4 so that it points to the correct url? Or is there anything else I could do to fix the issue? I would be very thankful for support or hints.
(The code, running from JSAPI4 Sandbox)
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>WMSLayer - 4.19</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.19/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.19/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/WMSLayer",
        "esri/Basemap"
      ], function (Map, MapView, WMSLayer, Basemap) {
          title: "WMS Layer",
          url:
        var map = new Map({
          basemap: "streets-vector"
        var mapView = new MapView({
          map: map,
          container: "viewDiv"
        map.add(wmsLayer);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Tags (3)
LukasWürsch
Hi Bjorn,
Thank you for having a look at the service, I see now what the problem is. As I do not have access to the geoserver, I created the following workaround using RequestInterceptor :
This changes the request url pointing to the incorrect geoserver url to a correct url before sending the request.
require([
        "esri/Map",
        "esri/Basemap",
        "esri/config"
      ], function (Map, MapView, WMSLayer, Basemap, esriConfig) {
var host = "https://developers.arcgis.com/"; // in case tested in the sandbox.
var incorrectGeoserverUrl = "https://developers.arcgis.com/geoserver";
var correctGeoserverUrl = "https://data.opendevelopmentmekong.net/geoserver";
esriConfig.request.interceptors.push({
  urls: host,
  // change request before it is sent
  before: function(params) {
    if (params.url.includes(incorrectGeoserverUrl)) {
      params.url = params.url.replace(incorrectGeoserverUrl, correctGeoserverUrl);
BjornSvensson
Esri Alum
I think the problem is that Mekong service is not set up properly.  The GetCapabilities is not giving a full URL in the resources' xlink:href
https://data.opendevelopmentmekong.net/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/wms?SERVICE=...
has e.g.
<OnlineResource xlink:type="simple" xlink:href="/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/ows?SERVICE=WMS&"/>
while for the ahocevar service you will see full URLs as in:
<OnlineResource xlink:type="simple" xlink:href="https://ahocevar.com/geoserver/ows?SERVICE=WMS&"/>
The best option would be to get the service fixed.
LukasWürsch
Hi Bjorn,
require([
        "esri/Map",
        "esri/Basemap",
        "esri/config"
  urls: host,
