JSAPI 4.1: How to load only the visible extent of a feature layer
2399
11-09-2016 10:15 AM
KevinHaeni
I'm having a feature layer with lots of polygons (>200'000 points). Usually, when I load it with JSAPI 4.1, it seems to be loading a random subset of the polygons, maybe 5000, but they are usually not in the visible extent.
How can I load only the polygons in the visible extent?
RickeyFight
Kevin,
I know this is possible with 3.18 but I am not sure about 4.1
I could not find it.
FeatureLayer | API Reference | ArcGIS API for JavaScript 3.18
MODE_ONDEMAND
In on-demand mode, the feature layer retrieves features from the server when needed. This is based on the requirements defined in the following properties:
  • Map properties such as the current spatial extent and time extent.
  • Layer properties such as time offset and definition expression.
KevinHaeni
Thank you! Meanwhile, I received an official answer mentioning that the current version 4.2 does not yet support loading polygons based on the visible extent.
I hope the DEV team is prioritizing this issue as the whole FeatureLayer seem pretty much useless when you have more features than what's reasonable for a MapService to return (5000-10000 features?).
Kevin
HyrumErnstrom
Anyone figure this out?
