JSAPI 4.0 released May 3, 2016
8443
12
05-03-2016 10:14 AM
BjornSvensson
Esri Alum
The ArcGIS API for JavaScript version 4.0 was released today. See the blog for a good overview, then head over to the developers site for details
yoavhermoni
very Annoying uncontrolled Default popup.
Impossible to control the popup size and position
And no command to hide the popup
KristianEkenes
Yoav,
To hide the popup, simply call the close method as documented here - Popup | API Reference | ArcGIS API for JavaScript 4.0
view.popup.close();
You can also simply set the the `visible` property to false.
view.popup.visible = false;
The popup's position can be controlled a number of ways depending on how you're using the popup. If you are passing features to a popup, the geometry will be used to position it (if available). Otherwise, the `location` property of the popup is used. The documentation for popup - Popup | API Reference | ArcGIS API for JavaScript 4.0  discusses these properties (features and location) and methods for working with the popup.
A popup's size can be altered with CSS.
If this didn't answer your question, then please add more specifics as to what you're looking for.
yoavhermoni
I tried These methods with no sucsses- probbely because of wrong sintaks or wrong posation location.
it will cause a big halp if you will add to the srorce below :
JS Bin - Collaborative JavaScript Debugging
1.control the size and position of the popup info window .
2.hide the popup window.
3.close the popup window
