jsapi 2.3 : measurement widget in meter
1379
05-25-2011 11:24 PM
Marie-GilSeptfonds
I'm trying to use the mesurement widget whith my mapservice in wkid = 2154.
I include the patch.js
When I measure in acre or miles it's ok, but when I measure in meter, the widget return NAN.
http://extranet.nimes.fr/website/extranet/AGS/test/mesure.html
thanks for your help.
Sylvain
KellyHutchins
Esri Notable Contributor
I ran your test app a few times and can't reproduce the issue with NAN when measuring in meters. Can you provide more details about how to reproduce? For example, does it only happen with large shapes or in a certain area?
Kelly
Marie-GilSeptfonds
Well, I measure a distance of 0,04 miles.
When I measure the same distance in Mètres the result is NAN Mètres
For areas :
I obtain 0.45 Acres
NaN Miles carrés
NaN Kilomètres carrés
0.18 Hectares
NaN Yards carrés
NaN Pieds carrés
NaN Mètres carrés
Can it be a localisation pb whith the difference between "," and "." ?
Sylvain
KellyHutchins
Yes this does look like a localization issue. I set my current locale to French and can reproduce the issue.
Marie-GilSeptfonds
JSAPI 2.4 solves this problem.
