JS - Turn on/off Map Layers
2878
11-07-2014 11:56 AM
ShaningYu
Honored Contributor
In a TOC panel, there are several Operational Layers, each one has a checkbox.  I added these layers by the piece of code below:
            var sliderTOC = new agsjs.dijit.TOC({
                map: map,
                layerInfos: [{
                     layer: operational1,
                     title: "by Site",
                    noLayers: true
                     layer: operational2,
                     title: "by Zip",
                     noLayers: true
                     layer: operational3,
                     title: "Distribution",
                     noLayers: true
                 }], style: 'inline'
            }, 'sliderDiv');             sliderTOC.startup();
Initially, one of the feature layer is on and others are off,  I want to add a such a function that when I click one of the checkbox, this layer is on and other layers are off.
Where and how can a piece of code be added to implement this function?  Thanks for your help.
Tags (1)
KenBuja
MVP Esteemed Contributor
Take a look at this post. It shows how to have only one layer on at a time.
