[JS API 4.9] IE11: Updating the map property on a MapView doesn't work
4592
11-05-2018 05:48 AM
SebastianKvist
Hello,
Since updating to v4.9, i have had issues in IE 11 with updating the map property of the MapView. It may work on the first update, but then the second change would error out.
I have addressed a similar use case in a previous question (related to the LayerList widget at that time): [JS API 4.x] SPA with multiple map configurations .
There is a sample from Esri in which one can re-pro this issue (in IE 11 that is): Swap web maps in the same view | ArcGIS API for JavaScript 4.9
Does anyone know if there is any workaround to this issue, or would I have to go back to 4.7/4.8?
Regards,
Sebastian
Noah-Sager
Update: Still unsure of a workaround, but we have this fixed for version 4.10 (due out in December). Thanks again for raising this issue to our attention.
Noah-Sager
Hi Sebastian, thank you for reporting this issue. Looks like a problem with 4.9. We are currently investigating. Not sure of a workaround at the moment, but I will update this thread when we learn more.
-Noah
Noah-Sager
