JS API 3.4 how to use dojo?
1463
07-16-2013 05:03 AM
UldisGitendorfs
I do not understand how and when to use
require([
        "dojo/_base/connect",
        etc.],
        function(connect) {
and when
dojo.require();
I have tried to use require([]) ... but nothing works.
Do I have to use this before any function???
Are there any extended examples on the net?
JeffJacobson
Don't use dojo.require().  That is the old way to do things. You should use the AMD method for new development.
Here is a sample on JSFiddle. Here's the same sample on Plunker.
JonathanUihlein
Thanks for posting a sample Jeff. His sample is adapted from this tutorial:
https://developers.arcgis.com/en/javascript/jstutorials/intro_firstmap_amd.html
This link goes over the new AMD style using require:
https://developers.arcgis.com/en/javascript/jshelp/whats_new.html
