JS API 3.13 - IdentifyParameters undefined?
5595
6
06-11-2015 02:19 PM
LauraMiles1
Hi All,
I've been struggling with this code, everything has been working until I tried to throw in the ability to identify. When I run the code, I get the error that identifyParams is undefined. Specifically, "Uncaught TypeError: Cannot set property 'geometry' of undefined"
Can anyone see what I've got wrong? Thanks in advance.
var map;
require([
    "esri/InfoTemplate",
    "esri/map",
    "esri/dijit/BasemapToggle",
    "esri/dijit/Popup",
    "esri/dijit/Scalebar",
    "esri/dijit/Search",
    "esri/Color",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/layers/FeatureLayer",
    "esri/layers/ImageParameters",
    "esri/symbols/SimpleFillSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/tasks/IdentifyTask",
    "esri/tasks/IdentifyParameters",
    "dojo/_base/array",
    "dojo/dom",
    "dojo/on",
    "dojo/query",
    "dojo/ready",
    "dijit/registry",
    "dojo/dom-construct",
    "dojo/parser",
    "dojo/domReady!"
    function(
  InfoTemplate,
  Map,
  BasemapToggle,
        Popup,
  Scalebar,
  Search,
        Color,
        InfoTemplate,
  ArcGISDynamicMapServiceLayer,
  FeatureLayer,
  ImageParameters,
        SimpleFillSymbol,
        SimpleLineSymbol,
        IdentifyTask,
        IdentifyParameters,
        arrayUtils,
  dom,
  on,
  query,
  ready,
  registry,
  domConstruct,
  parser
          var layer, visibleLayerIds = [], identifyTask, identifyParams;
          var popup = new Popup({
          fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
        }, domConstruct.create("div"));
          map = new Map("map", {
            basemap: "topo",
            center: [-123, 49.2],
            zoom:10,
            infoWindow: popup
        //Use the ImageParameters to set the visibleLayerIds layers in the map service during ArcGISDynamicMapServiceLayer construction.
        var imageParameters = new ImageParameters();
  //VFPA Boundary line layers (confirmed and non-confirmed) visible on startup
        imageParameters.layerIds = [0,2];
        imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
        //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
          var layerCadastral = new ArcGISDynamicMapServiceLayer("http://cop-gis4:6080/arcgis/rest/services/MOR/MOR_Cadastral_WGS1984/MapServer",
            "imageParameters": imageParameters
          map.addLayer(layerCadastral);
  //every time a layer is clicked, update the layer visibility
        on(dom.byId("chkVFPABoundary"), "change", updateLayerVisibility);
        on(dom.byId("chkMunicipalBoundaries"), "change", updateLayerVisibility);
  on(dom.byId("chkLots"), "change", updateLayerVisibility);
          function updateLayerVisibility () {
            var inputs = query(".list_item");
            var inputCount = inputs.length;
            //Dummy layer - is there a workaround? Setting this to an actual layer means that layer can't be turned off
            visibleLayerIds = [1001];
            for (var i = 0; i < inputCount; i++) {
              if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
            if (visibleLayerIds.length === 0) {
              visibleLayerIds.push(-1);
            layerCadastral.setVisibleLayers(visibleLayerIds);
  //Basemap toggle
  var toggle = new BasemapToggle({
            map: map,
            basemap: "satellite"
            }, "BasemapToggle");
  toggle.startup();
  var scalebar = new Scalebar({
          map: map,
          // "dual" displays both miles and kilmometers
          // "english" is the default, which displays miles
          // use "metric" for kilometers
          scalebarUnit: "dual"
  var s = new Search({
            enableButtonMode: false, //this enables the search widget to display as a single button
            enableLabel: false,
            enableInfoWindow: true,
            showInfoWindowOnSelect: true,
            map: map
         }, "search");
         var sources = s.get("sources");
         //Push the sources used to search, by default the ArcGIS Online World geocoder is included.
         sources.push({
            featureLayer: new FeatureLayer("http://cop-gis4:6080/arcgis/rest/services/MOR/MOR_Cadastral_WGS1984/MapServer/7"),
            searchFields: ["LOT_NO"],
            exactMatch: false,
            outFields: ["*"],
     displayField: "LOT_NO",
            name: "Lots - Lot Number",
            placeholder: "Lot Number",
            maxResults: 6,
            maxSuggestions: 6,
            //Create an InfoTemplate and include three fields
            infoTemplate: new InfoTemplate("Lot Number", "Lot #: ${LOT_NO}</br>Owner: ${OWNER}</br>Title Link: <a href =${TITLE_LINK}>Click to open</a>"),
            enableSuggestions: true,
            minCharacters: 0
         sources.push({
            searchFields: ["OWNER"],
            exactMatch: false,
            outFields: ["*"],
            displayField: "OWNER",
            name: "Lots - Owner",
            placeholder: "Owner",
            maxResults: 6,
            maxSuggestions: 6,
            minCharacters: 0
         //Set the sources above to the search widget
         s.set("sources", sources);
  s.startup();
        map.on("load", mapReady);
        function mapReady () {
          map.on("click", executeIdentifyTask);
          //create identify tasks and setup parameters
          identifyTask = new IdentifyTask(layerCadastral);
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [7];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
        function executeIdentifyTask (event) {
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          var deferred = identifyTask
            .execute(identifyParams)
            .addCallback(function (response) {
              // response is an array of identify result objects
              // Let's return an array of features.
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                var layerName = result.layerName;
                feature.attributes.layerName = layerName;
                if (layerName === 'Lots') {
                  var lotsTemplate = new InfoTemplate("",
                    "Lot #: ${LOT_NO} <br/> Owner: ${OWNER}");
                  feature.setInfoTemplate(lotsTemplate);
                else if (layerName === 'Building Footprints') {
                  console.log(feature.attributes.PARCELID);
                  var buildingFootprintTemplate = new InfoTemplate("",
                    "Parcel ID: ${PARCELID}");
                  feature.setInfoTemplate(buildingFootprintTemplate);
                return feature;
          // InfoWindow expects an array of features from each deferred
          // object that you pass. If the response from the task execution
          // above is not an array of features, then you need to add a callback
          // like the one above to post-process the response and return an
          // array of features.
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(event.mapPoint);
RobertScheitlin__GISP
Laura,
  You were trying to set the IdentifyTasks constructor to a layer object when it needs a url string.
corrected line:
identifyTask = new IdentifyTask(layerCadastral.url);
ChrisSergent
If you use Google Chrome, you can press F12 when you start up your application and then it usually tells you what it's looking for. Most of the time I have seen it as a typo or not declaring a variable with a var and then attempting to use it.
LauraMiles1
Hi Chris, I am using Chrome, and NetBeans. Using F12 unfortunately is not giving me any more enlightenment. I was able to get this esri sample working with my data but when I try to plop that into my existing map, I'm getting this error. I am fairly new to javascript and I think I've put something in the wrong order or something, but I don't know what.
ChrisSergent
Is your site public or can you post your page here: JS Bin - Collaborative JavaScript Debugging ?
LauraMiles1
It's not public nor are my services, but I've posted it and switched back to the service in the ESRI demo: JS Bin - Collaborative JavaScript Debugging
Laura,
corrected line:
LauraMiles1
Thanks Robert, that did it!
So in the ESRI sample, they had set the IdentifyTasks constructor the same way I had - I just switched out my layer for theirs. I'm guessing it is to do with the difference between how they added their layer to the map:
var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer";
        map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,
          { opacity: 0.55 }));
and how I added mine:
When I came to the line in the sample
identifyTask = new IdentifyTask(parcelsURL);
I just switched out parcelsURL for my layerCadastral. But in the sample parcelsURL was a variable that held the url string, so I'm guessing that's why it didn't work for me. Thanks both Robert and Chris for your assistance.
