Joining County Data from API to Feature Service
1521
02-19-2020 02:09 PM
EricSamson3
I am working on a web application that calls to an API and grabs county data in a json format. I have a feature service that shows county boundaries. I want to join the json data from the api to the feature service by the county ID, once the api is called.
I am seeing some options on how to do this using the leaflet API package, any suggestions on how to get this accomplished with the ArcGIS API?
Thanks
RickeyFight
Eric Samson
Are you planning for this to display in a popup?
EricSamson3
Yeah, essentially there is just one field I would like to join by the county ID layer which will contain a value. The feature service will then be colored by that value and the information will be available in a pop-up
