javascript debugging
5542
6
04-16-2015 07:06 AM
EntechEngineering
Hello,
I am trying to debug javascript for the web app builder in Aptana. It won't work for me, nor will the intellisense work.
RobertScheitlin__GISP
Entech Engineering,
   You can debug though your browsers web console. Aptana intellisense does not work for the JS API in newer releases of Aptana. See this link:
Code Assist Plugins | API Reference | ArcGIS API for JavaScript
ReneRubalcava
Esri Frequent Contributor
Code School has a free course on how to use Chrome Dev Tools.
Chrome Dev Tools Tutorial - Code School
FireBug and the newer IE11 debug tools are similar, so I think once you learn one, it's fairly easy to transition to others if you need to.
ChrisSergent
Here is a blog tutorial on debugging:Julie Pagano - JavaScript Debugging for Beginners
Noah-Sager
ChrisSergent
I had the second one Noah Sager​ but not the first. Thanks. I added to my list of links.
zhongrenGu
Entech Engineering:
      why did you use webstrom? it is suppot the dojo, if you set the path of esri'sdk, it will be a strong intellisense  IDE, if you  will use webstrom  ,i can teach you the use of webstrom
