Javascript API
6575
14
01-08-2020 12:42 PM
DeveshKhosla
Can we create API locally server not on the ESRI server.
ie. i have https://tiles.arcgis.com/tiles/Ezk9fcjSUkeadg6u/arcgis/rest/services/OPCNM/VectorTileServer
I want to create this api
https://localhost:5272/Tiles_VectorTileServer
ChrisSmith7
Honored Contributor
Noah,
The thread I linked earlier - Is it possible to render mapbox vector tiles (pbf) from a custom tile-server  - has information on doing this successfully using PostGIS, so it's not just in the realm of theory.
ChrisSmith7
Honored Contributor
So, for example, check-out:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=layers-vectort...
In this sample, you can see it closely aligns with the discussion in Is it possible to render mapbox vector tiles (pbf) from a custom tile-server, where this chunk of code is in the Esri sample:
url:
"https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer",
type: "vector"
...to simplify the other aspects, you would need the source (your server) to supply the expected JSON here - to quote:
You now need to serve your actual (pbf) tiles using the url pattern specified. In this example, that would be https://ourhost/oursource/{z}/{x}/{y}.pbf.
JosephGenther
ArcGIS Enterprise is the most robust tool for publishing raster imagery services. However, open source software may also publish in the supported formats that Noah Sager shared above.
Devesh Khosla What is your hangup for why you want an alternative to ArcGIS Enterprise? We may be able to help discover a solution that still fits your goals.
DeveshKhosla
Beacuse i want to display offline data. Api data only on my machine that's why I am looking for alertnative.
JosephGenther
Would it make sense to create an app using  an ArcGIS Runtime SDK with the local server capability? Direct read, write, and use of local raster, vector, and myriad other data options.
