Issues with IE 9
914
11-07-2011 12:56 AM
SanajyJadhav
I am seeing weird issues when viewing apps in IE 9. Issues are listed below.
#1. Cannot see the feature layer (comes from FeatureServer).
#2. Cannot see the overview map.
#3. Cannot see the polygon drawn by esri.toolbars.draw.We are using freehand polygon.Polygon is actually drawn because intersecting features are selected.However,I can't see the polygon.
I searched a lot on the forum but could not find anything specific.We are using version 2.5 for the API. I tested these things in IE 10 beta, every thing except #2 works fine.
Any help is much appreciated.
JeffPace
I have not seen this behavior.  Do you have a public site I could test against here?
SanajyJadhav
Thanks Jeff for the reply.
Unfortunately, this site is not on public domain.So, I can't show it to you. Any ideas, what might be causing this?
