Is there any IDE for ArcGIS API Javascript?
5139
6
04-26-2011 01:17 PM
XiujuZhou
I have developed ArcGIS API for silverlight by using Visual Studio.Net which has intellisense and error check. Now I start ArcGIS API Javascript. I am wondering if there is any IDE for it with intellisense and error check? Please help!
JamesGonsoski
I use Aptana Studio 2 (http://www.aptana.com/products/studio2). There are intellisense plugs-in available from the ArcGIS Resource Center. Query code assist plugin in the resource center or try this link.
XiujuZhou
Thank you very much! very usefull information. Let me try it.
XiujuZhou
Do I have to install plugin DOJO? It is failed to install it on my computer.
nicogis
another good ide is http://www.jetbrains.com/webstorm/index.html
you can do local and remote debug and you can add dojo (also help) and api esri for intellisense
nicogis
here I have made a video using basic viewer esri
" rel="nofollow" target="_blank">http://www.youtube.com/watch?v=cFHcgBMzeuQ[/video]
JoseSanchez
Good video!!
Do you use VS 2010 to create web ArcGIS API Javascript applications?
Have you find a way to use javascript and .net controls for example show a data resuls as  dataset in a .Net gridview  in a popup window?
Thanks
