is it possible to disconnect an onClick event listener?
5494
11-09-2010 04:19 AM
BradCochran
basically i want to enable and disable the onClick listener at will.  is this possible?
i see where you can do a dojo.disconnect(map, "onClick"); on unload but I want to be able to turn it on and off via a function.
if this isn't possible are there any other creative solutions to this problem?  i can achieve the desired effect I am after by just hiding the div that is getting the results from my onclick event, but this seems like a waste of resources.
thanks in advance.
derekswingley1
dojo.connect returns a handle that you can use to disconnect the event listener. Use something like this in your code:
var map_click_handle = dojo.connect(map, 'onClick' some_function);
dojo.disconnect(map_click_handle);
Of course that's a simplified example... Check out the docs for dojo.connect and dojo.disconnect.
AxelSchaefer
Please read the Concepts part of the ArcGIS Server JS-API documentation: Working with events
BradCochran
awesome thanks!
