Is an event fired when the map stops drawing?
1888
08-29-2010 04:09 PM
StephenLead
Honored Contributor
I'd like to add a "waiting" animation to my JS map, as in the sample at http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_showloadin...
In this sample, "the map's onLoad, onZoomStart,      and onPanStart events cause the loading icon to appear. The layers' onUpdate     events cause the icon to go away."
This requires listening for the onUpdate event on every layer that you add to the map, and anticipating every event which could cause the map to redraw (pan/zoom, previous/next extent, time slider change, etc).
Is there a way to listen at the map level, rather than the layer level? ie, is there an event fired when the map has finished doing everything? What is the last event fired by the map when it redraws for whatever reason?
Steve
GlenRhea
I am interested in this as well...
GeorgieCassar
Use map.onUpdateEnd()
StephenLead
Honored Contributor
Thanks Georgie.
OnUpdateEnd was added for the v2.2 release - I'd like to think as a result of this forum post 😉
Todd
(broken link)
Regards,
Todd
StephenLead
Honored Contributor
(broken link)
Hi Todd,
The new syntax is
map.on("update-end", function() {
  //do something
See https://developers.arcgis.com/en/javascript/jsapi/map-amd.html#update-end
Cheers,
Steve
