Invalid value for parameter Layers to Clip - Details :
867
10-08-2024 12:48 AM
FranciscoCaldeira
Hello everyone, with Arcgis PRO and the extract data task tool I have created a web tool to export a FeatureLayer as a zipped shapefile. The web tool only has one argument Layers_to_Clip (object of type GPMultiValue:GPFeatureRecordSetLayer) to identify the FeatureLayer to be exported. When I invoke the web tool I get the error: description: “Invalid value for parameter Layers to Clip - Details : ”
Does anyone have any idea what I'm doing wrong?
I have the following code
async function exportAsShp() {
    try {
        console.log(`Shapefile export initiated.`);
        const query = featureTable.layer.createQuery();
        query.where = "1=1"; // Select all features
        query.outFields = ["*"]; // Ensure all fields are included
        const results = await featureTable.layer.queryFeatures(query);
        if (results.features.length === 0) {
            console.error("No features found for export.");
            alert('No features found for export.');
            return;
        console.log("Number of features found for export:", results.features.length);
                 // Create a feature collection
                 const featureCollection = {
                  layerDefinition: {
                      geometryType: results.geometryType,
                      fields: results.fields
                  featureSet: {
                      features: results.features.map(feature => ({
                          geometry: feature.geometry.toJSON(),
                          attributes: feature.attributes
    const inputFeatureSet = new FeatureSet({
      features: results.features,
      fields: results.fields,
      spatialReference: results.spatialReference
        const params = {
            Layers_to_Clip: inputFeatureSet
        console.log("Submitting extract data job with params:", JSON.stringify(params));
        const jobInfo = await geoprocessor.submitJob(extractDataServiceUrl, params);
        console.log("Extract data job submitted. Job ID:", jobInfo.jobId);
        const options = {
            statusCallback: jobInfoUpdate => {
                console.log("Job status:", jobInfoUpdate.jobStatus);
                jobInfoUpdate.messages.forEach(message => {
                    console.log(`Message Type: ${message.type}; Message: ${message.description}`);
        const jobInfoCompleted = await jobInfo.waitForJobCompletion(options);
        console.log("Extract data job completed. Final status:", jobInfoCompleted.jobStatus);
        const result = await jobInfoCompleted.fetchResultData("Output_Zip_File");
        console.log("Extract data result:", result);
        console.log("Output Zip File URL:", result.value.url);
        // Abra o resultado em uma nova janela
        if (result.value.url) {
            window.open(result.value.url, '_blank');
        } else {
            console.error("Output Zip File URL not found.");
            alert('Error: Output Zip File URL not found.');
    } catch (error) {
        console.error("Error extracting data as shapefile:", error);
        alert('Error extracting data as shapefile. Check console for details.');
