Initial Exent changes at 3.7?
1421
10-03-2013 11:12 AM
DavidColey
MVP Frequent Contributor
Hi all,
I'm noticing an exent shift upon map load event at the 3.7 api that was not present at the 3.6 api.  For example, the exent:
  var extentWM = new Extent({
   "xmin": -9223319.21340548,
   "ymin": 3108650.4632008513,
   "xmax": -9102472.271686783,
   "ymax": 3178361.032996838,
   "spatialReference" : {
    "wkid" : 102100
seems to shift my map some 40 km south of where it should be on load. A tiled and dynamic map service are both configured as web mercator.  If anyone has any ideas, that would be great.
David
DavidColey
Hi all-
For those that are interested, it would appear that the parseOnLoad option must be set within the dojoConfig section when configured for asynchronous module loading in your index.html at 3.7:
   <script>
      var dojoConfig = {
        async : true,
        parseOnLoad : true
    </script>
As such, I would consider this thread answered
David
DavidColey
Hi all-
   <script>
      var dojoConfig = {
        async : true,
        parseOnLoad : true
    </script>
David
KenBuja
MVP Esteemed Contributor
You should mark your own post as the correct answer to help users who may be searching on this question.
DavidColey
Ah, thanks.  Should be all set.
