InfoWindowLite possible with tiled layer?
692
11-14-2013 09:28 AM
AZendel
I started with this sample on the ArcGIS JS page.  Then I switched the overlay layer to this web service on AGO.  I made the following changes
  • changed the layer type from FeatureLayer to ArcGISDynamicMapServiceLayer
  • changed the field names to what's listed in map service metadata
The overlay layer is displayed on the map, but no info window pops up when I click on the tract  / block group.
I tried:
  • adding "esri/layers/ArcGISDynamicMapServiceLayer" to the require statement
  • adding "ArcGISDynamicMapServiceLayer" to the map 'function'
But the overlay layer wouldn't display at all  - I removed them
If I download the layer file from the metadata and open it in ArcMap, I'm able to click the features and view the attributes, which suggests/confirms that the map service is capable of returning attributes.
I looked at the other examples of some sort of info window or pop up, but they all contain a FeatureLayer.  How do I provide the user with some sort of info / identify pop up when they click on the overlay?
I've uploaded my modified HTML document as a zip file.   Thanks for an insight you can provide
