InfoWindow title not visible Problem.............
3236
12-30-2015 01:46 AM
NadirHussain
Dear All,
Thanks in advance..In load function i am using
            parser.parse();
            var imageParameters = new ImageParameters();
            var startExtent = new esri.geometry.Extent(34.172358, 15.849254, 56.8245501, 32.2850301, new esri.SpatialReference({ wkid: 4326 }));
              map = new Map("mapCanvas", { sliderOrientation: "vertical", sliderStyle: "small", logo: false, "nav": true, extent: startExtent });
             map.disableMapNavigation();
             map.infoWindow.resize(250, 100);
on datagrid row click event i am calling below function
function QueryForSirenNumber(strSirenNumber) {
                 queryTask = new esri.tasks.QueryTask(strURL);
                 query = new esri.tasks.Query();
                 query.returnGeometry = true;
                 query.outFields = ["*"];
                 query.where = "SIREN_NO = '" + strSirenNumber + "'";
                 queryTask.execute(query, function (resultset) {
                    for (var i = 0; i < resultset.features.length; i++) {
                         var picGraphic = new esri.Graphic(resultset.features[0].geometry, new esri.symbol.PictureMarkerSymbol("Images/flag.png", 22, 22));
                         pt = resultset.features[0].geometry;
                         // alert(resultset.features[0].geometry.x + "__________" + resultset.features[0].geometry.y);
                         map.graphics.add(picGraphic);
                     map.infoWindow.setTitle("Coordinates");
                     map.infoWindow.setContent("Heeelllo");
                     map.infoWindow.show(map.toScreen(pt), map.getInfoWindowAnchor(map.toScreen(pt)));
Title of infowindow not coming.Please help.Thanks in advance.
NadirHussain
Dear robert,
I have one .css class in code having name .title.when i change it with titlebar.My infowindow start showing default behaviour.so i think there should no css having name title.
Thanks.
RobertScheitlin__GISP
Nadir,
   Are you setting the map.infoWindow some where in the code? By default the map uses a popup dijit for the infoWindow (unless you are setting it to an infoWindow dijit in your code). The popup dijit has a
titleInBody property which defaults to true. It would help to see more of your code and know what API version you are coding against.
NadirHussain
Dear robert,
Thanks.
