infoWindow border missing
1467
04-12-2013 09:21 AM
by Anonymous User
Not applicable
Original User: eboy2000
Hi All,
I got a strange problem with map.infoWindow display. The infoWindow was shown up with correct content, but the border disappeared. The feature works properly in another project I did before. I simply recreated the same feature in a new project. I have no idea why such issue occurred. :confused:
Attached two screen shots here. Appreciate if anyone can help. 🙂
Thanks in advance!
Andy
[ATTACH=CONFIG]23455[/ATTACH]
[ATTACH=CONFIG]23456[/ATTACH]
AndyZhou
Problem solved. It was due to a missing image file, soria.infowindow.png 😮
by Anonymous User
Not applicable
Original User: mhoover12
Can you give some more details on how you resolved this?  I've seen similar behavior on my boss' machine but it doesn't happen all the time.  What directory was the iamge file missing from?
AndyZhou
The image file is on the server side. If you know the application deployment path, the image file should be under associated "webContent/images" folder. If the image file is not there, you may download from internet and copy it into the "images" folder.
