InfoWindow and Panning
1710
5
01-17-2012 05:15 AM
MatthewZetterholm
Hello, everyone.
I am trying to use an InfoWindow as a container for some controls such as buttons and check boxes.
I'd like to be able to pan around the map underneath the InfoWindow without it moving.
My question is:  How do I get an InfoWindow to stay put in one spot on the screen as I pan around?
Thanks.
derekswingley1
I misunderstood. If you just want to put something on the map, put a div (or other HTML element) inside the map div and position your element. The simple KML layer sample shows this. Check out the markup for the div with id="meta" and the associated CSS.
derekswingley1
MatthewZetterholm
Derek,
Thanks for the reply.
On the sample maps the pop-up moves with the map as it is panned, but I need it to remain in place.
What I am trying to do is have a container with controls sit on top of the map (but detached from it).
Perhaps InfoWindows (Pop-Ups) are the wrong approach, but I'm not sure how else to superimpose a container on the map.
Thanks.
Matt
derekswingley1
MatthewZetterholm
That is what I was looking for.
Thanks for the help, Derek.
Matt
derekswingley1
Glad to help. Can you mark which post answered your question as an answer?
