infoTemplates and featureTemplates
1427
12-08-2010 02:51 PM
mdonnelly
I'm trying to edit the infoTemplate for a featureTemplate that I created. Basically, I want to change the format from the standard one that comes with the template picker.
Does anyone know how to do this?
Regards,
Mark
Regards,
Mark
mdonnelly
I'm not 100% sure this is the easiest way to go but it looks like I can use the feature template picker without the editor and program all the editor stuff myself.
Not exactly what I want to do as I like all the default editor handling. It's a hell of a work around just to get control of the infoTemplate.
Does anyone have any better ideas?
Mark
Regards,
Mark
mdonnelly
I'm attempting to replace the editor widget with my own code to get greater control of the infotemplate.
When I create a new feature using the template picker I then want to show an info window with the attributes of that feature class. However, I'm running into problems:
If I use the 'onDrawEnd' event with the following code, the info window does not show the attributes. It simply shows the literal infoTemplate string: '{*}'.
dojo.connect(drawToolbar, "onDrawEnd", function(geometry) {
     drawToolbar.deactivate();
     editToolbar.deactivate();
     var newAttributes = dojo.mixin({},selectedTemplate.template.prototype.attributes);
     selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
     var infoTemplateInst = new esri.InfoTemplate("Attributes", "${*}");
     newGraphic.setInfoTemplate(infoTemplateInst);
     map.infoWindow.show(map.toScreen(newGraphic.geometry), map.getInfoWindowAnchor(map.toScreen(newGraphic.geometry)));
If I use the 'onBeforeApplyEdits' event with the following code, info window does not show or is initially blank.
dojo.connect(featureLayers,"onBeforeApplyEdits", function(adds,updates,deletes) {
    dojo.forEach(adds, function(add) {
        add.setInfoTemplate(infoTemplateInst);
        map.infoWindow.show(map.toScreen(add.geometry),    map.getInfoWindowAnchor(map.toScreen(add.geometry)));
If I use the 'onClick' even with the following code it does work but it is initially blank. After I click again on the new feature, the info window displays correctly and continues to for subsequently created features.
dojo.connect(featureLayers, 'onClick', function(e) {
  e.graphic.setInfoTemplate(infoTemplateInst);
  map.infoWindow.show(map.toScreen(e.graphic.geometry),     map.getInfoWindowAnchor(map.toScreen(e.graphic.geometry)));
Has someone got an example of creating a new feature and then displaying an info window with the feature's attributes?
Regards,
Mark
mdonnelly
Sorry, my first example for 'onDrawEnd' is missing the line that creates a the new graphic:
     var newGraphic = new esri.Graphic(geometry,null,newAttributes);
Note, I have also tried putting the setInfoTemplate statement before the applyEdits statement but it made no difference.
Regards,
Mark
