Info Window Customization
858
05-25-2010 02:08 PM
GeoffreyMahase
I was wondering if there was a way to modify the way the info window resizes around it's anchors itself.
What don't I like?
Currently it anchors to the upper left or right and lower left or right.  So if you set the size, it expands the same way the anchor is declared.
What I want?
I want it to use up more of the screen.  I'd prefer if I could have it span the top left AND right of a graphic.
Can anyone recommend a way to modify it to do this? or do I have to create some new widget to accomplish this?
-Thanks
derekswingley1
GeoffreyMahase
That looks promising, thank you for the help.  Not sure if it'll fit my needs but it's a great place to start...thanks again.
