Import a Raster with geoprocessing published service
822
07-12-2017 02:54 AM
RadouaneSamaali
Hello all, I am trying to import files into the map, and I have succeeded to do with, using a drag and drop widget  that I found in github, but I found an issue that I cannot display (import) Raster file, so the last solution I thought about is to publish some geoprocessing services that would import Rasters into the bring"em to the map,
so the service I published called Copy_Raster, with parameters
ParameterExplanation
Configuration_Keyword__2_ (Optional)
The configuration
_CopyRaster
Output file
c41078a1_tif
input file
how can I use this service with ArcGIS API for JS, or do have a topic that would describe the steps to use the published services ...?
