IE7 Cross-domain issue with TitlePane digit
1167
11-30-2011 12:38 PM
by Anonymous User
Not applicable
Could someone explain to me why this first code example works in IE8 but but the second one doesn't.  I dont understand why I get the "Could not load cross-domain resources" error with the TitlePane digit but not other digits from esri.  It works right from dojo.
Ali
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html dir="ltr">
    <head>
        <style type="text/css">
            body, html { font-family:helvetica,arial,sans-serif; font-size:90%; }
        </style>
        <script src="http://ajax.googleapis.com/ajax/libs/dojo/1.6/dojo/dojo.xd.js"
        djConfig="parseOnLoad: true">
        </script>
        <script type="text/javascript">
            dojo.require("dijit.TitlePane");
        </script>
        <link rel="stylesheet" type="text/css" href="http://ajax.googleapis.com/ajax/libs/dojo/1.6/dijit/themes/claro/claro.css"
    </head>
    <body class=" claro ">
        <div id="tp2" dojoType="dijit.TitlePane" title="I'm a TitlePane Too">
            Click arrow to close me.
        </div>
    </body>
</html>
<html dir="ltr">
    <head>
        </style>
        <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"
        </script>
        </script>
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"
    </head>
        </div>
    </body>
</html>
KellyHutchins
Esri Notable Contributor
You need to create the djConfig object before including the dojo core (comes with ArcGIS API for JavaScript). Here's a modified version of your code:
<html dir="ltr">
<head>
</style>
<script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
</script>
</head>
</div>
</body>
</html>
by Anonymous User
Not applicable
I appreciate your help.  Unfortunately I still get the same cross-domain error with your modfied code in IE.  I get that the dojo core is part of the ArcGIS JavaScript API, so I don't understand why the ArcGIS version of the dojo core has this issue when the native dojo reference works fine.
KellyHutchins
In my testing it works fine with both in IE. I do not get cross domain errors. Here's a running test case:
http://jsfiddle.net/4gLJR/
by Anonymous User
Not applicable
Thanks again.  It seems to be working in IE7, but now I'm really confused.  Initially your test case still didn't work for me in IE 8.0.6.  I then clicked on the compatibility button and it now works even if I turn the compatibility mode off.  Thanks for your help getting it working.
