Identity manager, proxy page and secured services
872
08-13-2012 07:05 AM
ThomasLaue
I currently trying to build an application based on the JavaScript API V.3.1 and ArcGIS for Server 10.1 using secured services (token authentication). I am a little bit confused about the necessity of a proxy page when using the Identity Manager as the ESRI sample includes the well known proxy configuration ( esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";). However, the same sample works also quite well without this line of code.
Can anyone clarify this issue for me. Thank you very much for your help!
Thomas
PS: I am using some features services for editing tasks if this has any influence on the above question.
derekswingley1
The proxy is provided as a fallback for browsers that don't support CORS (IE 7 and 8).
