IdentifyTask returns empty array
2542
8
05-25-2022 02:19 AM
by Anonymous User
Not applicable
I am trying to get the graphics & objectid of a point on the map and am using the identifyTask. I am following this example. This is my code
this.map.on("click", function (e) {
                    _this.map.graphics.clear();
                    identifyTask = new IdentifyTask("https://server/arcgis/rest/services/MUNICIPALITY_BUNDLE/ZK_KATASTAR_NA_ZELENILO/MapServer");
                    identifyParams = new IdentifyParameters();
                    identifyParams.tolerance = 3;
                    identifyParams.returnGeometry = true;
                    identifyParams.layerIds = [0, 2];
                    identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
                    identifyParams.width = _this.map.width;
                    identifyParams.height = _this.map.height;
                    identifyParams.geometry = e.mapPoint;
                    identifyParams.mapExtent = _this.map.extent;
                    console.log("identifyParams", identifyParams);
                    identifyTask.execute(identifyParams, function (idResults) {
                        console.log("test", idResults);
idResults returns an empty array and I am unsure as to why.
Any ideas or pointers as to what I am doing wrong?
KenBuja
MVP Esteemed Contributor
Try setting the spatial reference to see if that makes any difference.
identifyParams.spatialReference = _this.map.spatialReference;
by Anonymous User
Not applicable
It's still the same.
KenBuja
Are the layerIds you're setting correct? Can you share the URL you're using to verify the process?
by Anonymous User
Not applicable
@KenBuja
Here are the layers
KenBuja
Then you'll want to modify this line since there is no layer 0. Your IdentifyTask would only include what is found is Layer 2. Include the layer ids you want to identify.
by Anonymous User
Not applicable
identifyParams.layerIds = [1];
identifyParams.layerIds = [1, 2];
I have made both of these modifications. For a fact, I know that the layer 1 has records in it and it still returns an empty array.
by Anonymous User
Not applicable
Whether I include all of the layers as above, or just one single layer it still returns an empty array.
RobertMEIER
try changing you layerOption value, the documentation says it should be a string, either "top", "visible" or "all".
