IdentifyTask on Raster layer with Polygon
1415
09-20-2012 11:42 AM
RobertDolormente
Documentation doesn't go into detail on this but I'm wondering how the IdentifyTask works when you execute the task with a polygon against a raster layer. Does it return an average of the "Pixel Value" or return the value of the center point of the polygon? Please help. Thanks!
derekswingley1
Are you talking about doing an Identify against and Image Server ImageService?
BenStewart
Bumping this question as I am having the same issue. I am NOT looking to query an Image Service. I want to run an IdentifyTask on a raster layer in a DynamicMapService using a polygon as input. Is this possible? The code sample I am using returns only one record. I assume it is the first or last coordinate of the ring, but I really want to get an array of all the values in the raster.
