identifyTask error when using timeExtent
1735
02-18-2011 07:44 AM
PatKeegan
I have an identifyTask that works fine until I add a TimeExtent to the identifyParams.
The map service is time aware and a time aware query task works on individual layers.
Does the identifyTask support a timeExtent?
thanks,
error:
Uncaught TypeError: Object 1293210666416 has no method 'getTime'
identifyParams.timeExtent = timeDef;
identifyTask.execute(identifyParams, function(idResults) { addToMapID(idResults, evt); });
derekswingley1
Yes, it works. I've used a time extent returned by getCurrentTimeExtent() from a time slider to set the timeExtent property on an identify parameters object. How are you creating your time extent?
PatKeegan
Thanks Derek!
Got it working, I did not have my global timeExtent updating properly.
myTimeExtent = timeSlider.getCurrentTimeExtent();
dojo.connect(timeSlider, "onTimeExtentChange", function(timeExtent) {
  console.log("time extent changed");
HeidiOgle
Edit: cancel that, figured it out.  Cheers!
