Identify with Popup not working in basemap osm
1559
06-17-2014 05:25 PM
ArowanaIndah
I'm working on multiple ArcGISDynamicMapServiceLayer IdentifyTask and i use this thread as a sample and it work. But i've some issue when i change basemap: "satellite" to basemap: "osm", identify popup didn't work.
Thank
<!DOCTYPE html> <html> <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <!--The viewport meta tag is used to improve the presentation and behavior of the samples       on iOS devices-->     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Identify with Popup</title>      <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">     <style>         html, body, #map {             height: 100%;             width: 100%;             margin: 0;             padding: 0;         }     </style>      <script>var dojoConfig = { parseOnLoad: true };</script>     <script src="http://js.arcgis.com/3.8/"></script>     <script>          var map;         var identifyTask, identifyParams, idPoint;         var identifyResults;          require([           "esri/map", "esri/dijit/Popup", "dojo/promise/all", "dojo/domReady!"         ], function (           Map, Popup, All         ) {             var popup = new Popup({                 fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]))             }, dojo.create("div"));              map = new Map("map", {                 basemap: "osm",                 center: [-83.275, 42.573],                 zoom: 18,                 infoWindow: popup             });              dojo.connect(map, "onLoad", mapReady);              var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer", { opacity: .55 });             map.addLayer(landBaseLayer);              var militaryLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/MapServer", { opacity: .55 });             map.addLayer(militaryLayer);               function mapReady(map) {                 dojo.connect(map, "onClick", runIdentifies);             }              function runIdentifies(evt) {                 identifyResults = [];                 idPoint = evt.mapPoint;                 var layers = dojo.map(map.layerIds, function (layerId) {                     return map.getLayer(layerId);                 });                 layers = dojo.filter(layers, function (layer) {                     if (layer.visibleLayers[0] !== -1) {                         return layer.getImageUrl && layer.visible                     }                 }); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers                 var tasks = dojo.map(layers, function (layer) {                     return new esri.tasks.IdentifyTask(layer.url);                 }); //map each visible dynamic layer to a new identify task, using the layer url                 var defTasks = dojo.map(tasks, function (task) {                     return new dojo.Deferred();                 }); //map each identify task to a new dojo.Deferred                 var params = createIdentifyParams(layers, evt);                  var promises = [];                  for (i = 0; i < tasks.length; i++) {                     promises.push(tasks.execute(params)); //Execute each task                 }                  var allPromises = new All(promises);                 allPromises.then(function (r) { showIdentifyResults(r, tasks); });             }              function showIdentifyResults(r, tasks) {                 var results = [];                 var taskUrls = [];                 r = dojo.filter(r, function (result) {                     return r[0];                 });                 for (i = 0; i < r.length; i++) {                     results = results.concat(r);                     for (j = 0; j < r.length; j++) {                         taskUrls = taskUrls.concat(tasks.url);                     }                 }                 results = dojo.map(results, function (result, index) {                     var feature = result.feature;                     var layerName = result.layerName;                     var serviceUrl = taskUrls[index];                     feature.attributes.layerName = result.layerName;                      var template = new esri.InfoTemplate("", "Service Url: " + serviceUrl + "<br/><br/>Layer name: " + result.layerName + "<br/><br/> Object Id: ${OBJECTID}");                     feature.setInfoTemplate(template);                      var resultGeometry = feature.geometry;                     var resultType = resultGeometry.type;                     return feature;                 });                  if (results.length === 0) {                     map.infoWindow.clearFeatures();                 } else {                     map.infoWindow.setFeatures(results);                 }                 map.infoWindow.show(idPoint);                 return results;             }              function createIdentifyParams(layers, evt) {                 var identifyParamsList = [];                 identifyParamsList.length = 0;                 dojo.forEach(layers, function (layer) {                     var idParams = new esri.tasks.IdentifyParameters();                     idParams.width = map.width;                     idParams.height = map.height;                     idParams.geometry = evt.mapPoint;                     idParams.mapExtent = map.extent;                     idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;                     var visLayers = layer.visibleLayers;                     if (visLayers !== -1) {                         var subLayers = [];                         for (var i = 0; i < layer.layerInfos.length; i++) {                             if (layer.layerInfos.subLayerIds == null)                                 subLayers.push(layer.layerInfos.id);                         }                         idParams.layerIds = subLayers;                     } else {                         idParams.layerIds = [];                     }                     idParams.tolerance = 3;                     idParams.returnGeometry = true;                     identifyParamsList.push(idParams);                 });                 return identifyParamsList;             }          });     </script> </head>  <body>     <div id="map"></div> </body>  </html>
KenBuja
MVP Esteemed Contributor
Unlike the standard Esri basemaps, the OSM layer doesn't have a visibleLayers property. Here's a way of checking for that in your code so that it works properly.
            function runIdentifies(evt) {                 identifyResults = [];                 idPoint = evt.mapPoint;                 var layers = dojo.map(map.layerIds, function (layerId) {                     return map.getLayer(layerId);                 });                 layers = dojo.filter(layers, function (layer) {                     if (layer.visibleLayers !== undefined) {                         if (layer.visibleLayers[0] !== -1) {                             return layer.getImageUrl && layer.visible                         }                     }                 }); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers
KenBuja
ArowanaIndah
Ahhhh fantastic! That is it!
Thank
