Identify ??? Popup sample: Customize for hyperlink
8452
10
11-16-2011 06:47 AM
JanBenson
I am trying to customize the Identify �?? Popup sample (under Find and Identify) from samples at http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm?Legend such that a hyperlink is enabled from the field name.  At present the hyperlink appears in the window, but it is not clickable.  I would like to instead have an alias name for the hyperlink.  When a user clicks on the name the hyperlink is activated.   In the function executeIdentifyTask (evt)  { there is an else if statement
else if (result.layerName === 'Building Footprints'){
              var template = new esri.InfoTemplate("", "Parcel ID: ${PARCELID}");
              feature.setInfoTemplate(template);
I am presuming PARCELID if the field name.  How would I make PARCELID as a clickable hyperlink?  Is there a way to put an alias name on PARCELID so the user would see somethink like URL or Link that would be clickable?
Thanks for any suggestions.
AdrianMarsden
Honored Contributor
This may help.  I have my site that is Independent  of script for the ID popup.  It cycles the layers and builds up the template from all exposed field aliases.
I also get a "more Info" hyperlink, based on the contents of a particular field - this is defined in the layer description in the MXD
You'll see a working example here http://maps2.eastdevon.gov.uk/mapping/assets/ you'll need to go the Planning & Policy group in the TOC (Key and other maps accordion) and select current planning applications to see the "more Info" link in action
ACM
PS just looked at that, and I really must change that layers symbology, I can hardly see it! This extent has a few examples as of today http://maps2.eastdevon.gov.uk/mapping/assets/?x1=311112&y1=87627&x2=311789&y2=88262
