Identify graphic and layers not playing well together
818
01-26-2011 06:14 AM
DavidMaltby
I have a pretty complex web map that incorporates graphic points as well as multiple layers into a map: http://txpub.usgs.gov/watershedreview When I identify layers it works great the first time (this is a double-click) when I identify a notes graphic it works fine; when I then go back to identify layers, it shows the graphic text.
I am completely stumped! It is probably the order of which javascript vars are loaded or executed.
Thanks in advance!!
