I can't unzip arcgis_js_v312_api.zip ?
4378
02-19-2015 07:27 AM
KarlWang
Anyone got this same issue?
I can't unzip the arcgis_js_v312_api.zip after I downloaded it.
G
RebeccaStrauch__GISP
If you have access to a different browser, try downloading it again.  I've had issues with other downloads before.  typically it's a setting I have in the browser (maybe blocking pop-ups, or other security setting).
ChrisSmith7
Honored Contributor
The MD5 hash should be listed on the download page as well if you want to compare and make sure there was no corruption during the download.
KarlWang
Thanks for your attention!How so I check it against the MD5 hash?
To: Karl Wang <[email protected]>
Sent: Thursday, February 19, 2015 1:02 PM
Subject: Re: - I can't unzip arcgis_js_v312_api.zip ?
reply from Chris Smith in ArcGIS API for JavaScript - View the full discussionThe MD5 hash should be listed on the download page as well if you want to compare and make sure there was no corruption during the download.
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS API for JavaScript by email or at GeoNet
Following I can't unzip arcgis_js_v312_api.zip ? in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Download Microsoft File Checksum Integrity Verifier from Official Microsoft Download Center   is where you can download the utility (called fciv) from Microsoft.
http://www.microsoft.com/en-us/download/confirmation.aspx?id=11533    (the actual address if you prefer)
Run the downloaded file to extract the fciv.exe to a known location .  Open a Command window and switch to the same location.  For command help, type      fciv    and hit entr...this will return the usage, and check out the readme file for samples.  Easier
     fciv -md -add file_or_folder_to_check
Example shown below to view a complete folder (folder 10.3 in this case). I can type in what is highlighted, and it will return all the md5 hashs for each file in the folder.
ChrisSergent
I used Google Chrome to download the file and had no problem opening the zip file.
