I am trying to use a featuretable in the 4.3 api but I can't seem to get it to work.
1899
07-27-2017 09:15 AM
PaulClausen1
Declaring the "esri/dijit/FeatureTable"  causes problems. Is there a sample set that shows how to implement in 4.3??
ThomasSolow
There is no feature table in 4.XX (yet).  Also, the 4.XX API uses "widgets" in place of "dijits."
by Anonymous User
Not applicable
What version are you using? If you are using 3.x the following link has all the samples related to feature table-
Samples | ArcGIS API for JavaScript 3.21
ThomasSolow
KenBuja
MVP Esteemed Contributor
And if you ever have a question whether 3.x functionality is available in 4.x, refer to this table:
Functionality matrix | ArcGIS API for JavaScript 4.4
PaulClausen1
Got it...
