How to use ArcGIS Identity Token to allow access to Dashboard
1520
04-18-2023 11:55 AM
ANRGIS
I am building a web application that uses ArcGIS Identity to authenticate the user and ideally provide access to a private embedded ArcGIS Dashboard without requiring additional sign in. I am able to set up the authentication and parse the token.
What I have not found is how to properly use the token to allow access to the ArcGIS Dashboard embedded in a portion of the application. I have not found anything in the documentation but have tried as the source of the iFrame src="<dashboard-url>?token=<token>" or src="<dashboard-url>?code=<token>" but both still show the pop-up asking for the user to sign again.
Is this possible? Or is there a better way to go about this?
GeorgetaPopa
Did you find a solution? What is the status? We would like to do something similar.
Thanks.
DavidHerries1
Did you find a solution for this? Been trying the same using php and JavaScript, but no luck so far.
