how to sort a featureset?
3745
10-10-2012 07:07 AM
SteveCole
Honored Contributor
Has anyone found or written a function to take a featureSet and sort it based on a specified attribute? The only way I can think of right now would be to:
  1. create a dojo dGrid via code
  2. provide the featureSet as it's store
  3. sort the dGrid based on the appropriate column
  4. create a new featureSet based on the sorted store
Thanks-
Steve
ReneRubalcava
Esri Frequent Contributor
You really want to sort on the featureSet.features array.
You can pass a function to the sort method to determine your sort.
I use this, but there's probably a better way to do this, since I need a text sort, not numbers or dates.
var _sort = function(field) {       return function(a, b) {         var x, y;         x = a.attributes[field].toLowerCase();         y = b.attributes[field].toLowerCase();          return (x < y) ? -1 : 1;       }; };  _featureSet.features.sort(_sort('FIELD_NAME'));
edit, had wrong file in clipboard
__Rich_
Vanilla JS - https://developer.mozilla.org/en-US/docs/JavaScript/Reference/Global_Objects/Array/sort
Or if you want to use Dojo, then you could push the items into a store (no need for a UI component e.g. dGrid) and then fetch them back sorted - http://dojotoolkit.org/reference-guide/1.7/quickstart/data/usingdatastores/sorting.html#quickstart-d...
Either way, you're going to need to write some code....
ReneRubalcava
SteveCole
Honored Contributor
Awesome! Thanks. I realized after posting that the datastore was more what I had in mind instead of the datagrid. At first, I thought that Rene's example would almost work for me since I do need to sort based on string values. My only catch is that I needed to sort by two fields (census tract being one and block group the other). As it turns out, there is a another field in my data which is a combination of the two which I had overlooked so Rene's code snippit works! Huzzah!
Thanks again!
Steve
__Rich_
Just for information, you could do that in the sort function. (I know you've got the concatenated field)
deleted-user-pYdfRjvSAbTJ
featureset is basically an array, you can use LinqJS to do everything you want with it
http://linqjs.codeplex.com/
