How to set BaseMapLayer opacity?
2359
7
07-27-2011 08:53 PM
StephenLead
Honored Contributor
The reference for BasemapLayer says that it includes an opacity setting, however I'm having problems getting it to work.
Using the sample here I add a setting to specify the opacity:
function createBasemapGallery(){
        //Manually create a list of basemaps to display
        var basemaps = [];
        var basemapRoad = new esri.dijit.Basemap({
          layers: [new esri.dijit.BasemapLayer({
            type: "BingMapsRoad",
            opacity: 0.25
          title: "Road"
This doesn't have any discernible effect - what am I doing wrong?
Cheers,
Steve
HemingZhu
        var basemaps = [];
            opacity: 0.25
          title: "Road"
Cheers,
Steve
Instead of set opacity on each basemap layer. you could try set it once:
var baselayer = map.getLayer(youbasemapid);
baselayer.setOpacity(0.25);
if you want to set up opacity differently for each individual basemap layer, you could use the above code in layer's onSelectionChange() event
derekswingley1
Steve- Thanks for bringing this up, it's a bug with the basemap gallery and bing layers. We'll fix it at 2.5. Until then, can you use the workaround suggested by Heming?
StephenLead
Honored Contributor
Hooray, an actual bug rather than doing something wrong!
No probs, I'll use the workaround for now. Thanks guys.
derekswingley1
Well done Steve!
derekswingley1
I know we had a workaround, but we did fix this in 2.5:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/new_v25.html
StephenLead
Honored Contributor
man, you are thorough. Thanks for following up on this (I'd totally forgotten)
derekswingley1
Just wanted to make sure we closed the loop on this one!
