How to return value from nested function to parent function?
6372
05-31-2013 10:58 AM
JoanSteinbacher
I have the following code working, but I need to return the value of the resultant "fieldInfos" string to the createFieldInfos() function and I'm not sure how to do that. Can anyone point me in the right direction?
Joan
function createFieldInfos() {
 console.log("-->inside createFieldInfos function");
 var endpoint = "http://gis.tpcmaps.org/ArcGIS/rest/services/LandUse/Existing_Land_Use/MapServer/0";
 var jsonobject = esri.request({
  url: endpoint,
  content: { f: 'json' },
  callbackParamName: 'callback',
  load: processServiceInfo,
  error: errorHandler
 console.log("jsonobject: " + jsonobject);
function processServiceInfo(info) {
 console.log('layer info: ', info);
 console.log("info.name: " + info.name + ",info.id: " + info.id);
       var fieldInfos = "";
       fieldInfos += "[";
 dojo.forEach(info.fields, function(field) {
  console.log( "Name: " + field.name + ", Alias: " + field.alias);
  if (field.name != "Shape" & field.name != "OBJECTID") {
   fieldInfos += "{'fieldName': '" + field.name + "',";
   fieldInfos += "'label': '" + field.alias + "',";
   fieldInfos += "'visible':" + true + "},";
 fieldInfos += "],";
 console.log("fieldInfos: " + fieldInfos);
function errorHandler(err) {
    console.log('error: ', err);
KenBuja
MVP Esteemed Contributor
This should do it
       fieldInfos += "[";
    fieldInfos += "],";
    return fieldInfos;
JoanSteinbacher
I've added that line but unfortunately it's still not working. Any other ideas?
JeffJacobson
Try this:
    var endpoint, jsonobject, fieldInfos = "";
        fieldInfos += "[";
        dojo.forEach(info.fields, function (field) {
            console.log("Name: " + field.name + ", Alias: " + field.alias);
        fieldInfos += "],";
        url: endpoint,
        content: {
            f: 'json'
        error: errorHandler
VinayBansal
Try this code
  url: endpoint,
  error: errorHandler
 return jsonobject.then(processServiceInfo, errorHandler);
       fieldInfos += "[";
 fieldInfos += "],";
return fieldInfos;
return null;
VinayBansal
Remove load and error function from jsonObject declaration
  url: endpoint,
