How to remove actionList items in InfoWindow/Popup
6903
03-28-2012 01:32 PM
ChadWilcomb
I have been able to successfully add items to the popup/infoWindow, like this
    var detailsLink = dojo.create("a", {         "class": "action",         "innerHTML": "Details",         "href": "javascript:void(0);"     }, dojo.query(".actionList", map.infoWindow.domNode)[0]);      dojo.connect(detailsLink, "onclick", function (evt) {         var feature = map.infoWindow.getSelectedFeature();         ExecuteViewPermit(feature.attributes.PermitNumber);     });
But how can I remove the default 'Zoom To' anchor tag?
I have tried adding variations of dojo/jQuery destroy/remove functions using the class selectors to my init and map onLoad functions:
dojo.destroy('.zoomTo');
$('.zoomTo').remove();
Any suggestions?
Chad
DavidSpriggs
The ZoomTo link has an additional css class assigned to it. To remove (actually hide) only the ZoomTo link, but leave the other links you have created, use this css:
.esriPopup .actionsPane .zoomTo {     display: none; }
StephenLead
Honored Contributor
You can knock it out in CSS:
.esriPopup .actionsPane {
    display: none;
DavidSpriggs
ChadWilcomb
Thanks David & stevel, why didn't I think of using CSS?
Incidentally, I used the same technique to knock out the maximize button on the popup as well...
     display: none;
.esriPopup .titleButton.maximize {
     display: none;
