How to query server-side FeatureTable?
3490
11
08-14-2024 02:11 PM
ForrestLin
Is it possible to query server-side FeatureTable without re-creating FeatureLayer?
Tags (1)
ForrestLin
I got a solution:
1. Create FeatureLayer:
       let featureLayer= new FeatureLayer({
              url,
              objectIdField: "OBJECTID",
              definitionExpression: "OBJECTID<0", // Make featureLayer no feature initially
             popupTemplate,
             renderer
2. Add featureLayer to map:
        view.map.add(featureLayer );
3. Create FeatureTable with featureLayer:
     const featureTable = new FeatureTable({
                   layer: featureLayer,
                   view,
                   container,
                   returnGeometryEnabled: true
     }); // FeatureTable has no record initially
4. Query FeatureLayer using definitionExpression:
        featureLayer.definitionExpression = query;
5. Update FeatureLayer using refreshand FeatureTable got updated:
       featureLayer.refresh();
MatthewDriscoll
You can bring it in as a FeatureLayer and query it the same as you would as a feature layer.
const bldPermLayer = new FeatureLayer({
    url: "https://.../server/rest/services/...",
    outFields:["*"]
    view: theView,
    layer: bldPermLayer,
function handleQueryResults() {
    let queryBP = bldPermLayer.createQuery();
    queryBP.where = "query"
    queryBP.outFields = ["*"];
    // do the query
    bldPermLayer
        .queryFeatures(queryBP)
        .then((response) => {
           // code
ForrestLin
@MatthewDriscoll
Thank you for your help!
Is it possible that FeatureTable get updated automatically when querying FeatureLayer?
MatthewDriscoll
What do you mean?  Are trying to edit a FeatureTable through a query?
ForrestLin
@MatthewDriscoll
    // do the query
    bldPermLayer
           // code
The  response is FeatureSet, right? How to update FeatureTable using the response? Or FeatureTable got updated already?
Thanks.
Forrest
MatthewDriscoll
Do what you want with it in the code.  It's the same data so it could go something like below.
    // do the query
    bldPermLayer
           featureTable.selectRows(response.features);
           featureTable.filterBySelection();
ForrestLin
@MatthewDriscoll
Thank you so much for your help!
The total number of features in my FeatureLayer is about 500,000. I just need to get/query/search about 20 features each time, and then show them in the FeatureTable.
I don't want to create a new FeatureLayer and add to map each time I query. What should I do?
Forrest
MatthewDriscoll
You don't need to create a new FeatureLayer each time, just query off the one every time.  In fact you don't need to add the FeatureLayer to the map at all.  You might need to loop through the response.features, but not sure that is necessary.
ForrestLin
I'm not sure how to update FeatureTable using the response.features.
These are just for selection of FeatureTable , not updating FeatureTable :
ForrestLin
I got a solution:
              url,
             popupTemplate,
             renderer
                   view,
                   container,
