How to Point Cluster With Dynamic Data In ArcGIS API
3118
08-27-2015 01:45 AM
BruceGreen
ArcGIS API is using This Demo to illustrate how Point clustering works with JSON data. In my case I am generating some point graphics from MySQL Database by a jQuery AJAX request like following code: As you can see I am storing the data in `project` and then access to `project.Longitude, project.Latitude` to create the points
   request.done(function( mapInfo) {
        for (var i = 0; i < mapInfo.length; i++) {
                var project = mapInfo;
                var point = new Point(project.Longitude, project.Latitude);
                var pointSymbol = new SimpleMarkerSymbol();
                pointSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
                pointSymbol.setSize(12);
                var pointInfoTemplate = new InfoTemplate();
                pointInfoTemplate.setTitle("Project Details");
                pointInfoTemplate.setContent('//JSON Data');
                var pointGraphic = new Graphic(point, pointSymbol).setInfoTemplate(pointInfoTemplate);
                points.push(pointGraphic);
    for (i = 0; i < points.length; ++i) {
            map.graphics.add(points);
Can you please let me know how I can bind this points with Cluster Points in ArcGIS API sample?
Tags (1)
