How to label point feature class (created dynamically ) in WAB ?.
4754
16
11-08-2017 04:31 AM
mohannainar1
The below labeling code is working for polygon layer (created dynamically) but not the point layer(created dynamically).
var statesColor = new Color("#060606");
var statesLabel = new TextSymbol().setColor(statesColor);
statesLabel.font.setSize("12pt");
statesLabel.font.setFamily("arial");
var json = {
"labelExpressionInfo": {"value": "{ENTITY_FIELD}"},"labelPlacement":"above-right"
var labelClass = new LabelClass(json);
labelClass.symbol = statesLabel;
this.temporalLayer.setLabelingInfo([ labelClass ]);
this.map.addLayer(this.temporalLayer);
Complete code for point layer is below . The dynamic layer is geographic coordinate system .
var pt = null;
var jsonFS = new Object();
jsonFS.geometryType = "esriGeometryPoint";
var features = [];
renderer = new SimpleRenderer(new SimpleMarkerSymbol());
renderer.symbol.setColor(selectedColor);
for (i = 0; i < this.fromExcel.length; i++) {
var attributeObj = new Object();
attributeObj.OBJECTID = i+1;
attributeObj.LATITUDE = this.fromExcel[this.config.LAT_FIELD];
attributeObj.LONGITUDE = this.fromExcel[this.config.LONG_FIELD];
attributeObj[this.mainField] = this.fromExcel[this.mainField];
attributeObj[this.config.TIME_FIELD]= this.fromExcel[this.config.TIME_FIELD];
attributeObj[this.config.SLIDER_FIELD]= this.fromExcel[this.config.SLIDER_FIELD];
attributeObj[this.config.ENTITY_FIELD]= this.fromExcel[this.config.ENTITY_FIELD];
var feature = new Object();
feature.attributes = attributeObj;
pt = new Point(this.fromExcel[this.config.LONG_FIELD],this.fromExcel[this.config.LAT_FIELD],this.map.spatialReference);
feature.geometry = pt;
features.push(feature);
jsonFS.features = features;
var featureSet = new FeatureSet(jsonFS);
var infoTemplate = new InfoTemplate(this.mainField + " : ${"+ this.mainField +"}", this.config.ENTITY_FIELD + " : ${"+ this.config.ENTITY_FIELD +"}<br>" + this.mainField + " : ${"+ this.mainField +"}<br>" + this.config.LAT_FIELD + " : ${"+ this.config.LAT_FIELD +"}<br>"+ this.config.LONG_FIELD + " : ${"+ this.config.LONG_FIELD +"}<br>"+ this.config.TIME_FIELD + " : ${"+ this.config.TIME_FIELD +"}<br>");
var featureCollection = {
layerDefinition:
"displayFieldName": this.mainField,
"geometryType": "esriGeometryPoint",
"spatialReference":
"latestWkid": 4326,
"wkid": 4326
"fields": [
"name": "OBJECTID",
"type": "esriFieldTypeOID",
"alias": "OBJECTID"
"name": this.config.LAT_FIELD,
"type": "esriFieldTypeString",
"alias": this.config.LAT_FIELD
"name": this.config.LONG_FIELD,
"alias": this.config.LONG_FIELD
"name": this.mainField,
"type": "esriFieldTypeInteger",//"esriFieldTypeInteger",
"alias": this.mainField
"name": this.config.TIME_FIELD,
"type": "esriFieldTypeDate",//"esriFieldTypeInteger",
"alias": this.config.TIME_FIELD
"name": this.config.SLIDER_FIELD,
"alias": this.config.SLIDER_FIELD
"name": this.config.ENTITY_FIELD,
"alias": this.config.ENTITY_FIELD
"name": "shape",
"type": "esriFieldTypeGeometry",
"alias": "shape"
}, featureSet: featureSet,
"exceededTransferLimit": false
var featureLayerOptions = {
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"],
infoTemplate: infoTemplate,
this.temporalLayer = new FeatureLayer(featureCollection,featureLayerOptions);
var extent = graphicsUtils.graphicsExtent(featureSet.features);
this.map.setExtent(extent.expand(1.2));
this.temporalLayer.setRenderer(renderer);
var json = {
mohannainar1
Robert,
Its 2.2
RobertScheitlin__GISP
Mohan,
   Because you are using WAB 2.2 you need to open the apps main config.json file and find the mapOptions object and add the "showLabels": true property.
mohannainar1
Already I have set that property , see the below code attached. . Label is working for dynamic polygon layer (same code)  . Its not working for the dynamic point layer.
"map": {
"3D": false,
"2D": true,
"position": {
"left": 0,
"top": 40,
"right": 0,
"bottom": 0
"itemId": "056a31fb8e614c06b69cf0c5ff9ca0d8",
"mapOptions": {"showLabels":true},
"id": "map",
"portalUrl": "https://servername:7443/arcgis"
Mohan,
   OK here is your widget working with lots of changes and cleanup (i have changed many files so be sure to use the whole zip).
mohannainar1
Hi Robert,
The above code is working for me if I use  esri base map . My scenario is my base map using  geographic coordinate system(gcs)4326 . If i use the above code for gcs base map label is not displaying and only points are showing on the map.
I have created a map service(gcs) in arcgis server and using that service as a  base map in my web app builder application . This is how I am consuming the base map , is that anything wrong in this approach ?
Mohan,
   OK, the fix is to parse the lat and lon field values before attempting to create a Point from them (use this whole updated function):
      CreateFCTimeSlider: function() {
        //debugger;
        var pt = null;
        if(this.temporalLayer) {
          this.temporalLayer.clear();
          this.map.removeLayer(this.temporalLayer);
        var features = [];
        for(i = 0; i < this.fromExcel.length; i++) {
          var dataAttr = new Date(this.fromExcel[i][this.config.TIME_FIELD])
          if(dataAttr.toDateString() == this.dateValue.toDateString()) {
            attributeObj.OBJECTID = i + 1;
            attributeObj.LATITUDE = this.fromExcel[i][this.config.LAT_FIELD];
            attributeObj.LONGITUDE = this.fromExcel[i][this.config.LONG_FIELD];
            attributeObj[this.mainField] = this.fromExcel[i][this.mainField];
            attributeObj[this.config.TIME_FIELD] = this.fromExcel[i][this.config.TIME_FIELD];
            attributeObj[this.config.SLIDER_FIELD] = this.fromExcel[i][this.config.SLIDER_FIELD];
            attributeObj[this.config.ENTITY_FIELD] = this.fromExcel[i][this.config.ENTITY_FIELD];
            var feature = new Graphic();
            pt = new Point(parseFloat(this.fromExcel[i][this.config.LONG_FIELD]), parseFloat(this.fromExcel[i][this.config.LAT_FIELD]), new SpatialReference({"wkid":4326}));
        var infoTemplate = new InfoTemplate(this.mainField + " : ${" + this.mainField + "}", this.config.ENTITY_FIELD + " : ${" + this.config.ENTITY_FIELD + "}<br>" + this.mainField + " : ${" + this.mainField + "}<br>" + this.config.LAT_FIELD + " : ${" + this.config.LAT_FIELD + "}<br>" + this.config.LONG_FIELD + " : ${" + this.config.LONG_FIELD + "}<br>" + this.config.TIME_FIELD + " : ${" + this.config.TIME_FIELD + "}<br>");
          layerDefinition: {
            "spatialReference": {
              "latestWkid": 4326,
              "wkid": 4326
            "fields": [{
                "name": "OBJECTID",
                "alias": "OBJECTID"
                "type": "esriFieldTypeInteger", //"esriFieldTypeInteger",
                "type": "esriFieldTypeDate", //"esriFieldTypeInteger",
                "name": "shape",
                "alias": "shape"
          outFields: ["*"],
          id: "ENTITY TEMPORAL DATA"
        this.temporalLayer = new FeatureLayer(featureCollection, featureLayerOptions);
        var labelColor = new Color("#060606");
        var entityTextSymbol = new TextSymbol().setColor(labelColor);
        entityTextSymbol.font.setSize("12pt");
        entityTextSymbol.font.setFamily("arial");
        var json1 = {
            "value": "{" + this.mainField + "}"
          "labelPlacement": "above-right"
        var lblClass = new LabelClass(json1);
        lblClass.symbol = entityTextSymbol;
        this.temporalLayer.setLabelingInfo([lblClass]);
        var rendererField = this.mainField;
        var min;
        var max;
        var minMax = [];
        numRanges = 5;
        for(i = 0; i < this.temporalLayer.graphics.length; i++) {
          minMax.push(parseInt(this.temporalLayer.graphics[i].attributes[this.mainField]));
        max = Math.max.apply(null, minMax);
        min = Math.min.apply(null, minMax);
        var breaks = (max - min) / numRanges;
        var outline = new SimpleLineSymbol().setWidth(1);
        var fillColor = selectedColor;
        var defaultSymbol = new SimpleMarkerSymbol().setSize(2).setOutline(outline);
        var classBreakRenderer = new ClassBreaksRenderer(defaultSymbol, rendererField);
        //add the breaks using the interval calculated above
        for(var i = 0; i < numRanges; i++) {
          classBreakRenderer.addBreak(parseInt(min + (i * breaks)), parseInt(min + ((i + 1) * breaks)), new SimpleMarkerSymbol().setSize((i + 1) * 6).setColor(fillColor).setOutline(outline));
        this.temporalLayer.setRenderer(classBreakRenderer);
mohannainar1
Hi Robert,
After including the parseFloat the label is working . Thanks for the Help.
