How to increase the speed of spatial query
1184
07-31-2017 09:53 PM
IT_AppLayers
hi all, I am using ArcGIS API for JavaScript v4.3 queryFeatures to get features in a layer.
var query = new Query({ returnGeometry: true, outFields: ["*"] });
query.geometry = geometryEngine.union(geometries);
self.censusLayers[layerID].queryFeatures(query).then(function (results) {
   //task/
Is there a way to increase the speed of execute this query? (assume the query geometries will be a 30 km radius circle and the query result will be 8000 SA1 geometries)
Thanks.
JayantaPoddar
Adding Spatial Index to the table could speed up the process.
Think Location
ThomasSolow
If you have all the geometries that you're searching for in the client then you can perform the query there, without making a network request.  In my experience the bottleneck is usually the network request, so performing the search in the client should speed things up.
Which version of the API are you using?  And for each "census layer," are all features in the client?  Or are they being fetched on demand (only available in the 3.XX API)?
