how to get values returned by esriRequest request Succeeded
1991
12-05-2016 10:44 AM
JoseSanchez
Hello everyone,
 I am testing a rest web service created in ASP.Net.
The rest service http://localhost:61004/api/value   returns one value:
  "value1"
I am testing also how to call this Restful service from esri javascript 1.38. This is the sample called "requests JSON using esriRequest".
https://developers.arcgis.com/javascript/3/jssamples/data_requestJson.html
I just copied it and set up the proxy and changed the default url
esriConfig.defaults.io.proxyUrl = "/proxy/";
dom.byId("url").value = "http://localhost:61004/api/aasis";
and it works!!!
My question now, is how do I get the content of "response" in a local variable to process it. My goal is to save this value in a field, but I do not know how to retrieve it.
     function requestSucceeded(response, io) {
               dom.byId("status").innerHTML = "";
               dojoJson.toJsonIndentStr = " ";
               dom.byId("content").value = dojoJson.toJson(response, true);   <<===============
 Thanks
RichardAbram
You would need to set that value in the requestSucceeded function.
if(evt.adds[0].attributes.hasOwnProperty('COMMENTS')){
                  evt.adds[0].attributes.COMMENTS =  response;
RichardAbram
the variable "response" is the value if the return is just text.  Do you send back a json string or just a value?  So is the web service returning text "value1" or something like this json string {'value':'value1'}?  If it is a json string then you need to parse it and reference the name otherwise use the value of response.
If you run this in IE or Chrome and put a break point in the requestSucceeded function you can see the format of the value that was returned
JoseSanchez
What is the best way to save in the field "evt.adds[0].attributes.COMMENTS"  the value "response" returned?
                  evt.adds[0].attributes.COMMENTS =   ????? ;  <<== value "response" from  function requestSucceeded
function getContent() {
var result = "";
var contentDiv = dom.byId("content");
contentDiv.value = "";
domClass.remove(contentDiv, "failure");
dom.byId("status").innerHTML = "Downloading...";
var requestHandle = esriRequest({
"url": dom.byId("url").value,
"handleAs": "json",
"callbackParamName": "jsoncallback"
requestHandle.then(requestSucceeded, requestFailed);
function requestFailed(error, io) {
domClass.add(dom.byId("content"), "failure");
dom.byId("content").value = dojoJson.toJson(error, true);
RichardAbram
